- Mute
12-28-2020 05:03 PM in
QLED and The FrameMy Frame TV occasionally auto increases the sound level, and then lowers it back to what I've set it for.
After a bit of investigation, I replaced the batteries in my controller and replaced my HDMI cable.
Even after removing the batteries from the controller, the sound level keeps rising and falling.
Changing channels has made no difference.
Any other hints?
Solved! Go to Solution.
- Mute
12-28-2020 11:36 PM in
QLED and The Frame- Mark as New
- Mute
- Mute
12-29-2020 07:39 AM in
QLED and The FrameThank you, zachjf2021...
Actually, my partner and I are doing puzzles or reading most of the time in the evening. By evening, the only time our TV is actually on, we both are relatively quiet-- and recently listening for this aboration in the sound.
If what you say is the case, then how do I defeat this 'feature'?
- Mute
12-29-2020 07:46 AM in
QLED and The FrameI found that our sound was on 'ambient' mode... which sound like it should do what you mentioned. I turned that feature off and will see what happens this evening.
Thank you again.
- Mute
12-28-2020 11:37 PM in
- Mute
12-29-2020 04:47 PM in
QLED and The FrameApparently I'm noiser than I thought!
Tonight the sound is just fine.
Thank you again!
- Mute
12-29-2020 05:22 PM in
- Mute
04-23-2021 09:57 AM in
QLED and The FrameWe also have this issue, when watching a movie, when there is "action" on the movie, it gets much louder. How can we have the same sound level all the time. PS we are not being noisey.
