Using Samsung remote to control Bose 321 system
(Topic created: 03-26-2023 01:28 PM)
userxEfzb6qDBF
QLED and The Frame
I have a QN75QN90BDFXZA tv and want to have the remote to control the volume of my Bose 321 system. I have it hooked up to an optical cable How can I pair these as of now they are paired with Direct TV remote.
Samsung_Moderator
QLED and The Frame
Hello! Thank you for reaching out! Using your remote to control your sound system can be useful. I would recommend using the link below to get this set up.
https://www.samsung.com/us/support/answer/ANS00049279/
If this does not help then you may have to connect your system via HDMI to get this to work. After you will just need to turn on anynet+. You can use the link below to get this set up.
https://www.samsung.com/us/support/answer/ANS00077511/
If you are still not able to get this to work you can call us directly at 1 (800) 726-7864 to get further support on this
1 Reply
Samsung_Moderator
QLED and The Frame
