multi audio output
(Topic created: 12-27-2021 10:27 AM)
userr4Iwd7K83X
QLED and The Frame
TV says multi audio output not available, can this be activated. I want to use headphones with my soundbar. Model # QN75Q7DTAFXZA
Not applicable
QLED and The Frame
Good afternoon, I will be happy to assist you with the audio setup. Unfortunately, the Multi-Output Audio feature is only available when using the TV speakers as the output device. It is not available using the sound bar.
1 Reply
Not applicable
QLED and The Frame
