2021 50” Frame - Samsung Remote control connectivity?
(Topic created: 07-25-2021 09:34 AM)
Samsung_0Q8C7hA
Qled and Frame
We are setting up the tv but cannot Select either option on the screen. The remote powers the unit on but nothing else. I am using the One Connect cable and box only at this point.
The remote QR code shows this: IDSRBN5901357ADTMFR4R6502
Help?!
SamsungLou
Qled and Frame
I will be happy to assist you. Have you performed the remote paining to the TV?
1 Reply
SamsungLou
Qled and Frame
