2021 Frame TV burnt my wall
(Topic created: 05-29-2021 10:11 AM)
userkUJPTb5N5r
Qled and Frame
2021 Frame TV burned my wall!
Has anyone experienced this? Should I be worried? Took my TV off to hide the wire today and noticed lots of burn marks and the wall was hot to the touch. I use Art mode but is set to turn off with the motion sensor which all seems to work fine. This does not seem normal! I got no response from customer service. @customerservice
SamsungAl
Qled and Frame
I'd like to have my specialized team take a look into this 🙂 Please send a private message to any of the moderators with the full model and serial number of the TV.
1 Reply
SamsungAl
Qled and Frame
