43” Frame missing wall mount
(Topic created: 07-28-2021 06:33 AM)
user0acJSQep8l
Qled and Frame
I just purchased a new 43” Frame but there was no wall mount box included. The only things I have are the two square brackets that come in the bag with the one connect cable, remote, power cable, etc.
SamsungLou
Qled and Frame
I will be happy to look in to this. Can you tell me where the television was purchased?
user0acJSQep8l
Qled and Frame
Thanks SamsungLou, the tv was purchased at Best Buy.
SamsungLou
Qled and Frame
Please send the full model and serial numbers to this PM Link.
user0Sx6iZNdTB
Qled and Frame
I also purchased a 43 inch frame tv (directly from samsung.com) and did not receive the no-gap wall mount.  How can I get it?
SamsungStephanie
Qled and Frame
Hello, I apologize for the part missing from your order. You will need to call our online support department and speak with an agent to obtain the missing part accordingly. The contact number is 855-726-8721 and they will be more than capable of assisting you from there with this matter.
user0Sx6iZNdTB
Qled and Frame
Calling that number yields no results!!  I've had the same problem and keep getting passed around.  Then they keep claiming it'll be shipped in 10-20 days or 8-10 days.  Just make something up every single time you call.  It appears that multiple customers are complaining about the same problem.  When will this be solved???
SamsungStephanie
Qled and Frame
Hello, I apologize for the issue you're experiencing and if you can send your full model code, serial number, e-mail, mailing address, contact number, or the part transaction number here PM Link in a private message I will be happy to obtain any information regarding an update for this concern reported if available.
