Highlighted
65 inch Q800T no gap wall mount
Which No Gap wall mount is compatible with the Q800T 65 inch?
I wanted to order both the tv and mount at the same time and  I only state this because the chat help could only suggest I look on the back of the tv...
4 REPLIES 4
Highlighted
Re: 65 inch Q800T no gap wall mount
Hello! We would recommend reaching out to our eCommerce team so that they can locate a compatible mount for the television. They can be reached at 1-855-726-8721
Highlighted
Thanks and just in case you come across this question again, I called and there isn't one available yet for this model.  It is a little sad that a customer needs to be the one to have to inform a  moderator though.
Highlighted
It has been 5 months since your post and when you go to the Q800T 65" model the Samsung site shows an incompatible mounting bracket for a 75" as their recommendation.  And when you choose any of the Samsung wall mount options and click on the link to 'show all compatible products', none of them bring up the 65" Q800T.  Pretty bad.
Highlighted
NO!
