Frame Specifications - Rear
(Topic created: 09-07-2021 01:25 PM)
Chuck1001
Qled and Frame
I am designing a new media room with plans for a 65" Frame.
I need to specify where an in-wall BlackBox should be installed. Can you furnish a schematic of the rear panel dimensions showing distance from top, bottom and side to mounting brackets and one-connect box?
Thanks
SamsungLou
Qled and Frame
I will be happy to assist you. The following chart has those dimensions, from the online Quick Start Guide.
Chuck1001
Qled and Frame
Thanks for the quick response but this is the vesa specs and not for the 65".
I need the distance from the Samsung mount's two brackets to the top and bottom of the Frame.
SamsungLou
Qled and Frame
I'm sorry, I must be confused. Are you asking for measurements and dimensions for after the mount is attached?
Chuck1001
Qled and Frame
Yes
foolish1
Qled and Frame
Yes I need help
Chuck1001
Qled and Frame
Will you be able to supply measurements from the installed brackets to the edges of the TV?
Thanks
