Frame TV: How to enter PIN in settings with smart remote?
(Topic created: 08-22-2021 06:38 AM)
userwdQzNQAeax
Qled and Frame
2021 Frame TV: in Settings I cannot find a way to enter the PIN (0000) because the remote supplied with the TV has no numeric keypad.  The settings screen does not allow on-screen numeric entry.   How can I enter the PIN?  I need to factory reset the TV.
userwdQzNQAeax
Qled and Frame
Found the answer: it is not possible to enter the PIN with the smart remote.   Samsung's quality test team missed this defect and there is presently no ETA on a fix.
Workaround:  use another Samsung compatible remote that has a keypad.   If necessary, find a universal remote and program it to work with the TV.
userwdQzNQAeax
Qled and Frame
SamsungStephanie
Qled and Frame
I am happy you were about to find your resolution and for providing the feedback. Thank you for being a valued part of our Community.
RRTodd99
Qled and Frame
How is using "another Samsung compatible remote that has a keypad" a valid resolution? Do I have to go out and buy another remote control?
I too have the problem where the TV turns off during ART Mode. It's been suggested that I reset the TV to factory conditions. Fair enough. But I can't reset the TV because I can't enter the default "0000" password on the reset screen.
Is there going to be software update to fix the problem?
RRTodd99
Qled and Frame
Ok, managed to use my Samsung phone as a remote control to enter the default "0000" password. But after resetting the TV it still turns off by itself! **bleep**
Edit: after looking around I found that it could be the Night Mode that was turning the TV off so quickly. Seems rather flaky but it appears to be working ... for now🤔
