- Mute
- Email to a Friend
01-14-2021 08:52 AM in
Qled and FrameWhen we first got our Frame TV and I installed the SmartThings app on my phone, every time we would turn on the TV, the TV would fail to connect to the internet. We would soft reset the TV, and then it would work fine, but we had to do it EVERY TIME we wanted to watch it. We did a factory reset and that seemed to solve the issue. However, a few weeks later when I added the TV back to the SmartThings app in order to upload some art, the issue came back. I'm wondering if anyone else has had this issue and found a resolution?
- Tags:
- Frame TV
- smartthings
- Mute
- Email to a Friend
01-18-2021 05:08 PM in
Qled and FramePlease go to Settings>Support and provide the full model code and current software version so that we can look into this for you.
- Mute
- Email to a Friend
a month ago in
Qled and FrameSure! The model code is QN50LS03TAFXZA and the current software version is T-NKMAKUC-1460.9,BT-S
- Mute
- Email to a Friend
4 weeks ago in
Qled and FrameYour software is up to date, once you turn the TV if you wait for a few minutes does it ever connected to the TV?
- Mute
- Email to a Friend
4 weeks ago in
Qled and FrameYes, our software is up to date, and the only way to get it to reconnect is to unplug it or do a soft reset (hold power button down to turn on).
- Mute
- Email to a Friend
3 weeks ago in
Qled and FrameHow long have you had this TV?
- Mute
- Email to a Friend
3 weeks ago in
Qled and FrameWe purchased it in November.
- Mute
- Email to a Friend
3 weeks ago in
Qled and FramePlease feel free to send me a private message with your full serial number. I would love to look into this further for you. http://bit.ly/2tCGnGK
- Mute
- Email to a Friend
3 weeks ago in
Qled and FrameWas this ever resolved, my TV has the same issue.
- Mute
- Email to a Friend
3 weeks ago (Last edited 3 weeks ago ) in
Qled and FrameHad the same problem.. Was using the router provided by AT&T... Added a new router (bridge)... No problems since
