11-15-2020
04:47 PM
- last edited on
11-15-2020
04:56 PM
by
SamsungAl
My Samsung Frame Model QN65LS03TAFXZA SN <HIDDEN> keeps disconnecting from the Wifi if the TV is inactive for several hours and won't reconnect unless I manually reset the wifi and then reenter the Wifi password all over again or if I pull the power cord out of the back and then put the power cord back in. I have tried different Wifi networks, manual IP address, updated the software, and read on the internet that many others have had this exact problem and Samsung has not generated a solution?
11-28-2020 12:30 PM
I have a similar issue with a 55 inch model LSO3T. I have reset my modem/router multiple times, and have reset wifi, manual IP address, etc. Nothing seems to work. Every time the system is off for a few hours it always requires unplugging the system and repowering. It is disappointing.
@userHf8LysFOzp wrote:My Samsung Frame Model QN65LS03TAFXZA SN <HIDDEN> keeps disconnecting from the Wifi if the TV is inactive for several hours and won't reconnect unless I manually reset the wifi and then reenter the Wifi password all over again or if I pull the power cord out of the back and then put the power cord back in. I have tried different Wifi networks, manual IP address, updated the software, and read on the internet that many others have had this exact problem and Samsung has not generated a solution?
12-07-2020 05:22 PM
This happens to me everyday too! I have another Samsung and same thing. On my other Samsung if I hold the power button down on the remote until it completely restarts and the "Samsung" pops up like a reboot, it works. This is hard to do with the Frame because of the picture screen.
12-15-2020 04:30 PM
Has anyone found a solution for this problem it renders tye rv almost unusable and doea th connext box come with some ariel. There seem to be a place for an ariel or antenna but i did not get one
3 weeks ago
I have the 75 (qn75ls03tafxza) . Got it 2 weeks ago. Have had the exact same issues as above, consistently. After an hour or two of innactivity, the TV disconnects from WIFI. I have completely powered down and restarted the TV, unplugged/restarted the WIFI, enterented in the WIFI IP into the TV manually, and the only thing that ever works and connects to the WIFI is when unplug the frame TV or reset my power.
Because I have the One Connect box mounted recess in the wall behind the TV, I have to shut off / turn on my main floor power EVERY time I want to use this TV.
I am extremely aggrivated/disappointed.
I'm going to reach out to Customer Support in hopes they can offer some sort of solution.
2 weeks ago
I had the same problem, but I did a factory reset and it solved it. I think for me, it's related to the SmartThings app on my phone, because as soon as I added the TV back to the app a few weeks after doing the factory reset, the problem came back. Very frustrating!
