HBO Max 4K HDR
With the recent announcement that HBO Max is going to offer 4K HDR content later this year, does anyone know if that will be supported by the HBO Max app used directly from the Samsung App Store/Tizen? The press release mentioned Apple TV, Firestick, etc... but no smart TV's. Thank you.
5 REPLIES 5
Re: HBO Max 4K HDR
The HBO Max app is available on TVs made in 2016 and newer.
Re: HBO Max 4K HDR
Yes, thank you.
But is streaming in 4K HDR going to be available through the app if I am watching directly through my SamsungTV and not a third party streaming device.
Thanks.
Re: HBO Max 4K HDR
As long as the TV has the capability yes.
Re: HBO Max 4K HDR
I'm sorry, but that doesn't remotely answer the OP's question.
The ability to stream 4k content is dependant on the HBO Mac app being updated on samsung tvs. Is the app going to be I be updated has it already?
Does anyone know version numbers we can check for?
Re: HBO Max 4K HDR
Definitely don't hope for any help from Samsung bc they are literally useless and have by far the worst customer service/experience that I've ever had to deal with.
