Help with firestick setup for QLED 85" 80T
(Topic created: 09-15-2020 07:16 PM)
userjOPPArhmWX
Qled and Frame
The firestick is asking what bit display the QLED 85" 80T 4K TV is.  The only options are 8 bit, 10 bit and 12 bit.  What should it be set to?  the default is 8 bit that seems low to me.
SamsungStephanie
Qled and Frame
Hello, I would recommend reaching out to Amazon Customer Service at 888.280.4331 concerning this.
1 Reply
SamsungStephanie
Qled and Frame
