How can I trigger an automation based on art mode on the Frame?
(Topic created on: 11/17/20 4:48 AM)
userOmcirOoKjz
Qled and Frame
I need to turn some Phillips Hue spotlights up or down depending on the mode of my 75" Frame using Smartthings. However, there is no option to say "spot lights on when in Art Mode" or "spot light off when i am watching television". Must admit I took that option for granted as I have seen other Samsung Qled TVs able to detect ambient mode. Any workarounds (or future development plans) for this?
SamsungLarry
Qled and Frame
I recommend reaching out to our SmartThings team. They can be reached at 1-866-813-2404 or emailed at support@smartthings.com
Be sure to click " βœ“ Accept as Solution" when you find an answer that works for you.
1 Reply
SamsungLarry
Qled and Frame
