Keep Monitor on with website displaying
(Topic created: 10-12-2021 07:12 AM)
userCUtMUGuHlX
Qled and Frame
We purchased a QLED Q60A Series 4K UHD TV to put in the narthex of our church to display real time info from energy production of our solar panels.  All goes well getting to the website and going full screen.  After a bit, however, the full screen goes to regular website, then the screen goes to screen saver.  So, does anyone know how to keep each of these from happening?
1 Reply
SamsungJam
Qled and Frame
If your PC is running Windows 10, you'll need to disable the screensaver.  Here are the steps: Select Personalization in settings. From the left sidebar, select the lock screen option. Scroll down and click on screen saver settings. Now click on the drop-down menu for 'Screensaver' and select 'None'
