Light leak QLED QE55Q77T
(Topic created on: 11/18/20 7:13 AM)
userGwdk8HnHx7
Qled and Frame
Hello, i recently bought a QE55Q77T and when i play movies etc with dark background the background is not black :p i Showed this picture to the service desk where i bought it and they told me that this is normal on a mid range tv. Is this true? First picture you can see clearly what i mean.
Thx
Eivind
125428357_867388624068770_7992301553954680936_n.jpg125922598_692201084758639_7122428774305337260_n.jpg
SamsungJam
Qled and Frame
Thank you for this information. This forum is for the support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry
1 Reply
SamsungJam
Qled and Frame
