Missing System UI animations on Q60T QLED
(Topic created: 03-31-2021 02:25 PM)
AxelDreemurr
QLED and The Frame
Just as the title says, the Q60T is missing all system animations (for example: the transition when scrolling through apps on the Smart Hub, app opening animations, etc.) and it's extremely frustrating, as last year's Q60R had this animations, I mean, you're paying for the "premium" experience...
Anyways, would be awesome if this gets fixed on a software update.
SamsungJustin
QLED and The Frame
Thank you for the feedback Alex, We'll make sure to tag your post for our engineers.
1 Reply
SamsungJustin
QLED and The Frame
