Multi View mode Samsung 2020 TVS not working
(Topic created: 10-31-2020 05:30 PM)
user6wSVuAJrPV
QLED and The Frame
Hello,
Just got the Q60T and the multi view mode isn't working. Called customer serivce to no results. None of my ios will work, it will just mirror the phone on the screen and not split into two pictures. Anyone know a fix? Has it worked before? Any info would be great. Seems like a software bug to me. Thanks in advance!
user6wSVuAJrPV
QLED and The Frame
So it looks like multi view mode is not supported on q60t but q70t and above even though the website says otherwise. I have the q80t and it works. A youtuber who reviewed the q70t says that it currently works on that tv.
SamsungJam
QLED and The Frame
I would be happy to look into this.  Could you provide the full model of the television?
user6wSVuAJrPV
QLED and The Frame
userTeSmX6aTnL
QLED and The Frame
Wow that's one of the reasons I went with this TV over the 70 is that it said this was an available feature? Is this software driven and able to be updated via the firmware? That is very disappointing and I just brought this TV home today.
poppopB
QLED and The Frame
That is EXTREMELY misleading as it still appears on the Q60T page with the small disclaimer "*Compatible devices only"   Where is the list of compatible devices?  "Watch TV and mirror your phone with Multi View" is also in the Solutions on the Q60T page.
user3HenjOQxPb
QLED and The Frame
I am having the same issue with my QN65Q6DTAF TV.  i have read through numerous post on these forums and not clear if it is possible with my specific model.  If it is, any and all guidance would be appreciated.   I called support twice and after an hour each call, they both ended with exact same comment,  “...I will research and call you back in 20 minutes...”.  That was 3 days ago with no return call.  Thanks in advance for your help!
