PS5 and Q95T Audio issues
(Topic created: 10-05-2021 01:39 AM)
userY6lFPwdnEd
Qled and Frame
Hello
First time poster.. after many months of googling a solution I have decided to make a post as I can't seem to find an answer...
I have  Q95T and PS5 connected via the HDMI 2.1 port ( Port 4 on the one connext box) and TV connected to a HwQ60T sound bar through ARC port .. I believe it's port 2 or 3.. I am not running the PS5 through the sound bar
The issue the PS5 starts with no sound 80% of the time ..
A restart of PS5 fixes it everytime  and I get sound but then I would 70% of the time it won't register 2.1  connection and only output YUV22 color output and not RGB .. and the out put settings on PS5 only give upto HDR 60HZ
Another restart mostly fixes the issue and it will go back to RGB color showing a supported max 120HZ ( I know you can only get 120HZ with YUV22 due to 2.1 speeds but I'm only outputting 60HZ so should get RGB)
But I'm  sick of having to restart the PS5 3 or 4 times to get sound and RGB color output ..
Has anyone else experienced this or has a fix. Both tv and PS5 are upto date software wise
Thanks
