user60eFQBqqRj
Q6FN does not hold source settings
For sources entries of type HDMI or component video that are not automatically detected by TV, such as PS4 or Chromecast, the manual settings are erased when turning off the TV.
E.G.: I move the VC source on the home list of the TV, move it ahead of the list and give it a name. When I turn it off and let it off for  aprox. 15 mins this setting is lost, the component source is back to the hidden source list without the given.
This is very bad in term of ux because each time I need to access the VC or other entry not listed on the initial apps list it is a long way to get it.
FW version: T-KTM2uAbc -1202.3, BT-S
3 REPLIES 3
userF8bBIHugLn
Re: Q6FN does not hold source settings
Sounds like you are set up in retail mode instead of how me mode. Look in manual
user60eFQBqqRj
Not really, I checked this. Also for example, the image configuration it does not restart. Only the sources that are not automatically detected by AnyNet are not stored.
Looks like to me a FW bug.
userBYrHuUjPjc
I set up a new sound bar and it workd fine. After turning off TV for the evening, when turned back on the HDMI option in the audio source has dissappeared and defaulted to TV speaker. If I unplug the power cord, the icon returns and sound bar is fine, turn off tv, repeat. Any ideas. Firmware updated to latest.
