Highlighted
Q80T 75 inch crackling sound from left speaker
Just bought this expensive TV.  I finally got to sit down and watch TV (Away on Netflix)  and I began hearing a crackling sound. It is unbelievably annoying. Its only on the left side. Volume is set to 40 so I'm not cranking it.  I do not want to get a sound bar after spending almost $3,000 on a TV.
Anyone else have crackling sounds?  Should exchange at the store?
2 REPLIES 2
Highlighted
Re: Q80T 75 inch crackling sound from left speaker
I'm sorry to hear that, does this occur on all sources? If this does then it would be recommended to take it back for an exchange.
Highlighted
I ended up exchanging it at the store. Problem seems to be fixed!
