- Mute
- Email to a Friend
β12-05-2017 04:26 PM in
Qled and FrameMy tv is brandnew. When i am connected to my xbox one x. Every 4-6 of use i will see the screen flash intermittently and back to normal. It happpens sooooo fast. I have tried two different xbox one x units. Both outputing at 4k 60z. 10bit. I have tried two different brandnew hdmi cables designed specifically for the one x. I have tried different ports on the one connect.
What do you guys think this is? Audio does not get interrupted.
I plan on testing to see if the powerstrip/surge protector i am using is bad. I ordered a very expensive surge protector with filter to reduce noise. I am planning on turning off uhd hdr. I plan on testing the xbox at 1080p and then testing my old xbox one . This will probably all take a week at least cause its very hard to replicate the flash
Solved! Go to Solution.
- Mute
- Email to a Friend
β12-04-2018 10:03 AM in
Qled and FrameIn additional to enabling/disabling UHD Color, do you guys mess with the other Picture Settings also?
- Mute
- Email to a Friend
β12-04-2018 01:44 PM in
Qled and Frame- Mark as New
- Mute
- Email to a Friend
β12-04-2018 01:54 PM in
- Mute
- Email to a Friend
β12-04-2018 02:59 PM (Last edited β12-04-2018 03:01 PM ) in
Qled and FrameGuys thanks for keeping this Thread active. Did another picture reset and now using Standard mode instead of Movie mode for last 3 days. Have not seen a Flash with my TiVo Bolt but had a big flash while watching Blu ray movie with ps3 still.
- Mute
- Email to a Friend
β12-05-2018 01:25 PM in
Qled and FrameNew firmware/software available for 2017 Qled 1260.6 not sure yet if it fixed the flashes will monitor.
- Mute
- Email to a Friend
β12-08-2018 06:09 AM in
Qled and FrameQuestion. Do you use the sharpness setting at all in whatever picture mode your using?
- Mute
- Email to a Friend
β12-08-2018 03:20 PM in
Qled and FrameIm not 100% sure, but i may have finally figured out the cause and solution to this issue. Everyone try turning the sharpness off by taking it all the way down to 0. I tried this because i was having other recurring issues beside the flash on certain 4k discs. On one movie the black bars (top and bottom of screen) would flicker. On another movie (with heavy film grain), anything that was dark, black or near black would flicker. I have never turned the sharpness completely off before. always had it at 20 or slightly higher. Once i turned it off, all of these issues went away, and i havent seen a screen flash since. I think its possible that all of my other issues and the flash could be related to the sharpening level. If you think about it, if you have the sharpness turned up, the tv is basically trying to sharpen an already 4k image. I may still yet see a flash, but i have a good feeling about this one. I will update soon, but everyone please try this.
- Mute
- Email to a Friend
β12-08-2018 05:14 PM in
Qled and FrameI have always had the Sharpness set to 0 and still had the White or other colors flashes. I just watched a Blu ray movie with ps3 and saw one Large flash. Thought maybe new 1260 firmware was the fix. Can someone tell me when they do the Picture test with kids on the beach and select Yes do you see Grey screen?
- Mute
- Email to a Friend
β12-08-2018 06:27 PM in
Qled and FrameOH no. I guess 0 sharpness just fixed my other issues then. I will assume a flash is coming soon. I'm sure I was just getting my hopes up cuz this flash has become one of most annoying things in my recent memory. And yes I get the grey screen on the picture test after the 1st picture
- Mute
- Email to a Friend
β12-09-2018 05:53 AM in
Qled and FrameThanks for the grey screen info now I know it's just not my tv. Others out there with 2017 QLED models please chime in and let us know if you are still seeing a "White Flash" using any device (Tivo, Cable boxes, PS3 or PS4 etc).
