QN55Q80RAFXZA 55 inch QLED popped and won't turn on
(Topic created: 08-30-2021 04:12 PM)
userBQ20dNrAnM
QLED and The Frame
My SAMSUNG QN55Q80RAFXZA Flat 55-Inch QLED 4K Q80 Series Ultra HD Smart TV, purchased less than 1 1/2 years ago, just made a pop noise and now won't turn on, either from the remote or the controls on the base of the unit.   i checked the power cable which is intact and plugged in, the electrical socket, which was good,(and I tried plugging it in elsewhere), none of which helped.
The unit is plugged into a surge protector, and we've had no other indications of power surge or other problems.
Please assist.
SamsungAl
QLED and The Frame
Ah, thank you for confirming! It seems like the next course of action would be to have the TV serviced. I would be happy to see what I can do for you 🙂 Can you shoot me a private message with the serial number and software version of the TV?
SamsungAl
QLED and The Frame
By trying to plug it elsewhere, does that mean you plugged it directly into the wall outlets? A lot of the time surge protectors prevent TVs and gaming consoles to work properly.
userBQ20dNrAnM
QLED and The Frame
I did plug it directly in to test after it failed.  No surge protector, and I verified the new outlet was working.
SamsungAl
QLED and The Frame
userBQ20dNrAnM
QLED and The Frame
How do I send a private message?
MrLarry
Neutron Star
QLED and The Frame
Just click on any moderator's name and there will be a blue button under the picture saying send a message.
