userdoS8kt9Bp9
Re: QN65Q9FNAF - Audio Stutter
I bought a Q7 a couple weeks ago and I am experiencing the same thing.  It goes away after a while or if I change the channel.  Has there been any resolution?
userfojKZMSRqJ
I purchased a brand new Samaung 55" Q8F 55QNQ8F.  I've used the TV for a combined 8 hours so far and am having similar sound stuttering issues.  Every 60 seconds or so the sound goes out and comes back sporadically sometimes once and sometimes for a good 10 seconds before it stops for another 60 seconds or so.
This is crazy.  Less than a day and a $2000 TV.  Was supposed to be my entry into owning a top of the line.  Had zero issues with my Sony soundbar and Samsung 40" (from 6 years ago) or my HiSense 40" just as old.  So the only TV in my house with issues is the brand new Q8?  Come on....
J_R-15
I purchased a  QN65Q9FNAFX  QLED and I have also been experiencing the audio stuttering issue.  I have a Sony soundbar connected via an Optical Audio cable to the Sony.  It stutters more frequently when you have the TV audio set to Internal Speakers and have the Optical Audio cable connected to the soundbar.  The frequency seems to be every 15 or 20 minutes the audio stutters for 5 seconds or longer.  Changing the channel or pausing the TV then returning to the program then the stutters stops.  I change the Internal Speaker setting to Off and left the audio output set to Optical Audio Out an the stuttering of the audio occurs but just occassionally.
I am using a Dish Hopper.  Then the 4K Joey with 4K High Speed cables conneted between the 4K Joey and the QLED TV.  Then an Optical Audio cable to the Sony Soundbar.
JuNiTo79
Just got my tv a few days ago and i sat down to watch my first movie and Im having the same problem!! Any solution to this?
J_R-15
Do you have a sound bar or using internal speakers on the TV?  What Model TV? Are you using Digital Optical Audio cables or HDMI?
I contacted Sony and they suggested for troubleshooting you place the input and output setting on the TV from Bitream to PCM since I am using a Sony soundbar the uses the Optical Audio cable (only supports 2 channel audio per there support) and not HDMI.  I did this for a few days and this seemed to resolve the issue.  Then as a test, I ran the audio direct from the Dish 4K Joey to the sound bar and bypassed the TV.  This works as well but the TV speakers would have to be used for any internet programming like Netflix, etc. coming from the TV via the internet.  This also stopped the stuttering issue.
I need to circle back to this issue with the PCM with Samsung.
JuNiTo79
I got Samsung Q965, Samsung n950 soundbar and samsung blu ray and have the same problem! Smiley Sad
J_R-15
I would open up a ticket with Samsung so they have multiple customers complaining about the same issue.  They need to handle digitial bitstream audio in the TVs better than they do today.
J_R-15
Another item to check if you are connecting devices via HDMI and if you have 4K equipment, are the quality of the HDMI cables.  The HDMI cables need to be high speed cables that support 4K.  The data rates are much higher than standard HDMI cables.  They are around 18GBs instead of rated at 10GBs per second.  They also have gold tips so you can tell the difference from standard HDMI cables.  The devices communicate with each and if they cannot because of degradation in the signal or speed related issues strange things happen to the final audio or video.  Long HDMI runs like 25 to 30 feet become problematic as well without special devices.  These are items that are commonly overlooked.
Goalasso
Cosmic Ray
Same issue here. Brand new Q965FN with one connect box. Optical cable to my Sonos Playbase. Source is my Direct tv genie 4K mini.  Interestingly, I don’t recall ever having an issue using another source such as Netflix or Apple TV. Could it be the Direct TV setup? All the same symptoms and remedies tried in this thread. Not happy about it. Who has a phone number to actually speak with a US Samsung support person? Thanks in advance.
userElP1KaEWQS
Having the same issue with my Samsung UN65NU800D and a Samsung HW-MM55C soundbar. I get this choppy sound every so often and it's annoying. Had the TV for about 1 month before getting the soundbar for xmas and never had the choppy sound. So it has something to do with the soundbar being connected. I've tried both the optical cable and now the HDMI and experienced the choppy sound with both set ups. I already threw out the box for the surround sound so what can I do?
