Qn90A US model 85 have local dimming issue.
(Topic created: 08-25-2021 10:17 PM)
useruHjjefa4IY
Qled and Frame
Qn90A US model 85 have local dimming issue. I saw some other post shows same issues. when the TV wake up from sleeping(soft power on), the local dimming fail to properly change the brightness. and Local dimming set to high is as dim as low, and even dimmer than standard. So the TV stuck at a pretty dim status.   Only hold the power button for long time to do a hard reboot will solve this temporarily, and after we soft turn off the TV and turn back on later , the same issue reoccur. Please fix this and this issue has been reported several month ago.
1 Reply
Qled and Frame
Is this happening on all HDMI sources and TV native apps? How long is the TV powered off before you have it back on and experiencing the issue?
