- Mute
06-11-2020 08:34 AM (Last edited 06-30-2023 03:54 PM by SamsungAl ) in
QLED and The FrameI just purchased the new Sonos Arc soundbar that supports eARC. It works with my 2020 65" Frame TV until I change the eARC setting on the Frame TV to Auto. The sound mutes and I can't get it to play until I turn eARC off. Has anyone else encountered this?
Solved! Go to Solution.
- Mute
01-16-2021 12:29 PM in
QLED and The FrameThis issue is not resolved, the thread should not be marked as such.
- Mute
03-02-2021 12:21 PM in
QLED and The FrameHi,
has anyone tested the new version 1462.1?
is the problem with the SONS arc sound solved?
regards
- Mute
03-07-2021 08:42 AM (Last edited 03-07-2021 08:43 AM ) in
QLED and The FrameIt didn’t help anything. Same issues.
- Mute
04-06-2021 03:48 PM in
QLED and The FrameStill not resolved dolby atmos sound cuts outs every 10-15 mins it seems
- Mute
03-08-2021 04:54 AM in
QLED and The FrameI have the same issues. Sound from my Sonos Arce is dropping out every few seconds.
I have the Samsung The Frame 65'' 2020, with firmware 1460. The workaround I do, and have been doing since I got the Arc in January is to disconnect and reconnect the HDMI-cable on the Sonos Arc after starting to play some content on the TV.
I tried to download version 1497 from the Netherland support page, but i got update failed twice when trying to install the update on the TV via USB stick. (I'm located in Norway if that should matter)
Here is a link to 1497 if someone want to try:
https://www.samsung.com/nl/support/model/QE65LS03TASXXN/
- Mute
04-26-2021 11:15 PM in
QLED and The FrameI had a problem with the sonos arc not working after turning off the TV. I turned off "instant on" under the hidden menu of the TV to cure another issue where the wifi drops after turning off TV. Turns out, it fixed both issues!
Enter the hidden menu with old Samsung remote or ask the help line too turn off "instant on"
- Mute
10-10-2021 03:40 PM in
QLED and The FrameI am having the same issue with a 55” 2021 Frame TV and a Sonos Beam gen 2.
Does turning off “instant on” have any other affects? Like does the TV take longer to turn on?
I don’t want to try a fix that causes more problems than it solves.
- Mute
10-25-2021 01:18 PM in
QLED and The FrameYou wouldn’t believe what worked for me!
*** Try a different HDMI cable ***
I had the exact same issue on my new 75’’ Samsung QN90A.
Nothing worked. I tried everything mentioned here.
Then I tried the HDMI cable that came with the Sonos Arc, instead of the other I had connected. Poof! Everything worked instantly. The TV notified me it detected a Dolby Atmos device, and everything was in sync.
- Mute
10-21-2021 07:51 PM in
QLED and The FrameI have multiple Q80T TVs that are all paired with a Sonos Arc. About twice an hour while I watch TV, the sound will cut out for a second and then return. This issue is specific to the pairing of the device with Samsung since it works flawlessly when used as a speaker for music via Sonos. What can I do to fix this? Thanks in advance.
- Mute
11-08-2021 07:02 AM in
QLED and The FrameThis is the issue we all have. The only way to stop it is to go into the audio settings, expert settings, and turn HDMI e-ARC mode to "Off". Insane that Samsung won't address this. It's been years.
