Samsung 75in qn90a local dimming problem
(Topic created: 06-13-2021 07:45 PM)
cev214
Qled and Frame
Just purchased a 75in qn90a and am having an issue where the local dimming seems to stop working randomly out of no where,switching between low,standard and high won't work and the tv will look dim,only way to fix it is to do a long press on the power button then the local dimming feature will eventually work again,happens randomly since I got it..
cev214
Qled and Frame
Really Wana keep this tv since it's amazing but am still under my return window not sure what to do
Diaboyos
Supernova
Qled and Frame
If you're not 100% satisfied don't let the return window pass. If it is a problem with the TV it's only going to get worse over time.
