userHLHJBzCTg9
Re: Samsung QLED TV Turning Off and On by itself, remote not responding!!! Still Waiting for a fix!!
JUMP TO SOLUTION
   I bought the 65" QN65Q7FA QLED from New Egg, and it worked fine for literally 2 weeks.  It started doing the reboot thing.
  I should've just returned it to New Egg, but instead went through Samsung.  The tech was friendly enough with good English, but said they'd just ship out a new One connect box (or whatever it's called).
  I KNEW when I installed the TV, that it was bad design to rely on that device.  The only connection my TV has is power and the One Connect fiber optic cable.  So if the box ever breaks (like mine did less than 14 days old) then you're screw ed.
  I requested the item be overnighted, the tech claims he put the note on the shipment order but we'll see.
  This thread is huge with TONS OF PEOPLE HAVING THE SAME PROBLEM.   Obviously there's a defect going on, they need to make it right.   I should've just paid slightly more for the Sony one :*(
userBjRHdVLRI6
JUMP TO SOLUTION
You hit the nail on the head.  My feedback to samsung team is with new technology like this, there should be an extra interface installed on the display that will provide a basic connection.  So that when there are problems, customers can still functional use the display.
Best regards
usereL8eRGE0BF
Cosmic Ray
JUMP TO SOLUTION
Does the newer model NU8500 have oneconnect box or they got rid of it?
userR32pD9ISeo
JUMP TO SOLUTION
I have a 2018 q8fn that keeps turning on and off by itself. Two days old
Not applicable
JUMP TO SOLUTION
@userR32pD9ISeo Reach out via Private Message with the full model and serial number. We can look into this. https://bit.ly/2mQxylV
userH7Eo96CtTs
JUMP TO SOLUTION
Have you updated the firmware? Go to the Samsung website and download the file and unzip the file.
userCSiTP5tD5W
JUMP TO SOLUTION
Hi, I currently have the Q7 and also downloaded the new firmware...but when i go to tv settings to update it says that i have newer version even though it searches through the usb...it didn't find anything newer than i have. my current version is 1103 and the file i downloaded is 1131.9 and still not upgrading. i don't have problem with tv turning off but i do have some HDR stuttering on my ps4 when playing fifa18. what can i do?
JUMP TO SOLUTION
Could you provide the full model of your television?
JUMP TO SOLUTION
Please get that to us as soon as you can.
userQV4tncg3D6
JUMP TO SOLUTION
just went through this exact issue ... brand new QLED 65" Q9F ... with one connect box ... worked great for two weeks. Had it mounted and the problem with turning on and off started. Numerous calls with tech support ... nothing helped. They sent me a new box ... same problem ... I called and asked to send me a new cord (didn't send with the new box) ... got it and the TV is working perfectly ... so, try a new cord ...
