useraGUTqGwRNL
Re: Samsung QLED TV Turning Off and On by itself, remote not responding!!! Still Waiting for a fix!!
JUMP TO SOLUTION
Technician visit yesterday.  Came prepared to replace components within the monitor or oneconnect box but as we took the monitor off the wall he realized the cable type and immediately asked, "does your remote freeze as well?"  When I replied, "yes it does." We put the TV down and he retrieved a new cable.  After cable replacement the TV is no longer showing the issue.  He was 99% confident this would resovle the problem but kept the ticket open and is following up today.  Good luck to those that are experiencing the problem and I hope you get resolution.  My thanks goes out to SamsungHeath who helped me through this.
JUMP TO SOLUTION
We're glad that you're up and running!
userZ904baWQSY
JUMP TO SOLUTION
Purchased Q9 two weeks ago. Same problem started last week. Told to download latest update. Did that but still shuts down. Very disapointed
JUMP TO SOLUTION
@userZ904baWQSY Please send us a private message with the full model code and serial number: Link
Eric Etherson
JUMP TO SOLUTION
Sigh... Wish I had read this forum before I bought a Q9 same as you pal.
1 week in, exact same problems. Luckily I bought mine direct from Samsung and kept the box in my garage so I think I'm just gonna save myself any drama and just get a refund.
Krome
JUMP TO SOLUTION
Purchased a 2018 75 inch Q9F last Wednesday from Best Buy. Same problem with the tv turning off and on by itself and the remote locking up with the flashing red light AFTER ONLY 2 DAYS!!! Already downloaded the latest update and turned off the HDR and power off, etc. etc. Seems I need a new connect one box and cable sent to me, BUT how long before this fails again since Samsung has obviously ignored this issue for the last 2+ years with so many complaints. Very angry and disappointed with Samsung and the thousands of dollars and time wasted on this known defective product!
JUMP TO SOLUTION
Can I please have your full model number and serial number in a private message?
userLY00Kf8Oc6
JUMP TO SOLUTION
I'm experiencing this issue now for the first time, I've owned this tv since mid December.
user1OjubeUPut
JUMP TO SOLUTION
I have the same exact issue.  Model:QN75Q9FNAFXZA.  Purchased in December 2018.  Tv turning on and off every three minutes or so.  Completely unacceptable!
Not applicable
JUMP TO SOLUTION
@ user1OjubeUPut I would be happy to investigate further. Can you send a Private Message here: http://bit.ly/2UWU6k4 with the full serial number of the unit?
