Highlighted
Select Button not working for Samsung Smart TV q70 LED
The select button will not work on the remote for my brand new samsung q70 LED tv. This is also the case when I use the Smart Things app on my phone. Every single other button works fine and I still get the red indicator showing that a signal's being sent to the TV when I click the select button but it does nothing.
1 REPLY 1
Highlighted
Cosmic Ray
Re: Select Button not working for Samsung Smart TV q70 LED
If it also doesn't work using SmartThings remote app then your remote is ok. I would first pull the plug on the TV for 5 mins, and if that doesn't work do a full reset of the TV.
