Highlighted
TV Q80R Volume Control does not work
JUMP TO SOLUTION
Out of box, volume control is doing somethig else.
Left button is doing mute, right is Nothing.
Note: Volume is working with old tv remote, and Roku remote.
Tried:
- Hard reset, (holding power 50 sec, removing batttaries)
- Reconnect (holding near right lower corner of tv, two buttons together to get reconnected)
1 SOLUTION
Highlighted
Re: TV Q80R Volume Control does not work
JUMP TO SOLUTION
It is QN55Q80RAFXZA but i doubt ithis is a relevant question since all Q80R have same remote.
Update:
Spoke with support: Quickly tried to reset, reconnect, we'll send a new remote.
For community benefit, this is what i learnt:
- To reset remote, take out battaries, hold power 10 seconds, put battaries back.
- To reconnect remote, hold two buttons, back and pause.
- To find serial number, go to settings->about.
The problem with remote is way too common, I downgrated my Samsung rating and stopped recommending to my friends as a relyable TV.
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
What's your TV model code?
Highlighted
JUMP TO SOLUTION
Update:
Highlighted
JUMP TO SOLUTION
My friend, that's right. To change the volume you need to "push" this VOL button UP or DOWN toward top or bottome of the remote.
