- Mute
- Email to a Friend
01-05-2021 12:42 PM in
Qled and FrameI am absolutely outraged at the way Samsung treat loyal customers. I have only bought Samsung TV's and phones for the last 20+ years. A 75" QN75Q7FNAF QLED TV I purchased in February 2019 has suddenly started turning off and on by itself. It turns on and off so quickly that no picture even appears. They only way it stops is leaving it unplugged. I reaserched this issue and found numerous posts of others experiencing the same issues. I have tried every possible thing that was mentioned. Keep in mind, Samsung knows full well about all these issues, but continues to act like it's a new thing. I called Samsung and set up a service appointment on 12/29. The guy just left after not doing anything because he said, it may be a certain part and he can change it and it will cost $300+, but if it not that part then they have to come back and I have to pay for a new one connect box and cable because that may be the problem. So in other words, I have to pay for the repairman to try different things each time and see if it works. What??? So I decided to message support trough Facebook. Here's the conversation:
Me:
Solved! Go to Solution.
- Tags:
- No help from Samsung support
- Samsung needs to do a recall
- TV automatically turns off and on
- TV turns on and off by itself
- Mute
- Email to a Friend
01-05-2021 01:12 PM in
Qled and FrameI am sorry to hear about this. Please send the ticket number to this PM Link, and I will be happy to review your case.
- Mute
- Email to a Friend
- Mute
- Email to a Friend
Saturday in
Qled and Framesorry i cannot tell if there was any resolution to this. i have a similar situation that just started last night all of a sudden. my tv (58Q60) was purchased in Sept 2020 and should be covered under warranty. tks
- Mute
- Email to a Friend
Sunday in
Qled and FrameSamsung finally made things right. Nearly 2 months later! The most helpful people were the ones responding to these messages. I got vey little help from Samsung's 800 number or their Facebook page. So thank you to all the people from Samsung HERE that helped me out.
