- Mute
09-09-2021 05:36 PM in
QLED and The FrameI am trying to setup a brand new 65” Frame TV. The remote control worked until I began the setup process. Now the power button is the only thing on the remote thst works. How do I reset the remote?
Solved! Go to Solution.
- Mute
09-09-2021 05:47 PM in
QLED and The FrameHello, I understand how frustrating that can be, and apologize for any inconvenience. I was able to locate the information here TV remote to assist with resetting the television remote. If the information provided is unsuccessful, you will need to provide the full model code of the television for further review.
- Mute
- Mute
09-09-2021 06:43 PM in
QLED and The Frame
