The Frame motion sensor starts the tv - not art mode
(Topic created: 06-24-2021 04:07 AM)
user2yLcIHI0nm
Qled and Frame
Hi. This may be fixed by a simple setting but I can’t find it or any information online.
At night after watching tv I will change to Art mode on my 50 inch the frame by using the remote. When I go to bed the tv will switch off as expected because I have night mode on.
The problem is that in the morning when I get up, the motion detector will see movement but instead of opening art mode it will start the tv. This can be problematic if the tv was the last thing watched and the volume is up loud.
Is this something I can fix with a setting?
current settings are - night mode on, motion detector medium, sleep after 15 mins
1 Reply
Qled and Frame
Do you have the 2020 or 2021 model? My 2021 picks back up on art mode in the morning whenever my movements trigger the motion detector.
