help my tv wont turn on
(Topic created: 09-10-2021 06:26 PM)
userP2N0O1coqN
Qled and Frame
Model: SOC 1000MA
Model Code: QN75Q7FAMFXZA
Version No: AA01
All of a sudden, for no apparent reason, the display stopped turning on. I confirmed power is available and the cables are plugged in. The remote is confirmed to be working with the flashing red LED. There are no standby lights visible on the TV or the One Connect box.
1 Reply
SamsungAl
Qled and Frame
Is the TV plugged into a surge protector or a wall outlet directly? Have you had any power outages recently?
