Showing results forĀ
Search instead forĀ
Did you mean:Ā
Battery Drain more than normal ? Maybe!
(Topic created: 11-18-2021 09:42 AM)
Questions
How has everyone's battery drain been ? Not sure of it's apps not optimized or the Beta. I've seen more than normal but it's early and maybe just using more apps to check how they look and respond to update.
youu
Supernova
Questions
Did u clear the cache, battery life has been almost the same for me
Bl8ck-c8t
Cosmic Ray
Questions
I even cleared the cache still feels like my battery draining more than usual.
USBetaModerator
Beta Moderator
Questions
Hello @userYH8Z5rlNsv ,
Please erase the device cache using steps below. If issue persists, Please update Samsung members app to latest version from galaxy store and send us an error report from the Samsung memberā€™s app -> Beta Feedback -> Error Reports to help us debug the issue.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Side key.
  3. When the Android logo displays, release both keys.
  4. An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
  5. Press the Volume down key several times to highlight Wipe cache partition.
  6. Press Side key to select.
  7. Press the Volume down key to highlight Yes, then press the Side key to select.
  8. When the process is complete, Reboot system now is highlighted.
  9. Press the Side key to restart the device.
Regards,
One UI Beta Team
Questions
Yes I always clean cache when I update my phone's. Thanx
