Dragneel
Halo
- Mute
03-05-2025 10:48 AM (Last edited 03-06-2025 08:39 PM ) in
Questions
Since the Beta 4 release, my Buds2 Pro cant be used for calls.
Can someone tell me HOW I can fix it? This is an issue with the Beta
Update:
I looked up how to reset them, but didn't work.
Restarted my phone, and they worked perfectly... I think the software must've been bugged or something
JD931
Galaxy
- Mute
03-05-2025 01:34 PM in
Questions
My buds2 pro work normal like always. Try resetting your earbuds
Negropy
Galaxy
- Mute
03-05-2025 03:30 PM (Last edited 03-05-2025 03:30 PM ) in
Questions
Perhaps unpair and pair again? Mine work just fine.
USBetaModerator 3
Beta Moderator
- Mute
03-06-2025 09:41 AM in
QuestionsHello,
Thank you for the feedback.
If the issue persists after unpair/repairing or resseting your earbuds, please submit your error report via Samsung Members.
Regards,
One UI Beta Team
