Buds3 Pro Not Showing in Wear, Not showing in settings, please assist if possible
(Topic created: 09-10-2025 04:03 AM)
GalaxySpanner
Questions
S24 Ultra - One UI7 And15 - Brand New Pair o Buds3 Pro
Not Showing in Wear, connected fine when first opend case, works fine, plays music, calls all tha jazz, but....
How the **bleep** do i modify any settings? Like noise cancellation or Equaliser settings? Basically anything?
I've seen other posts where buds3 pro is now supposedly supposed to show up under the main settings menu, i see nothing.
Like i said earlier its connected fine, and when i go to bluetooth, yeah its there, great. I have 3 options other than the 2 toggles for calls & audio, which are Rename, Disconnect & Unpair......
**bleep**..... Why aren't they discoverable nor available to add in wear? Why don't i see this mythical option in the settings menu? Yeah my buds work, but why can't i manage them?
RedOregon
Comet
Questions
They show up in the settings menu on top only when connected. Easier way to get the settings is to drop the widget on your screen. It'll always be available. Most of the settings are greyed out until you connect, just like before.
GalaxySpanner
Questions
And when they don't?
KSal
Nebula
Questions
They are overthinking things by changing just to change. They need to move them back to the wearables app. I was in the same boat. Luckily I had a widget to adjust them.
userlQcCM1wRc8
Black Hole
Questions
100% overthink! The ecosystem was great in the wearable app.
No need to fix what isn't broken.
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for sharing your feedback on the new change on Buds settings.
Once you open the case, you will see a popup of your buds on your screen, followed by a Wearable setting under Setting.
For easier access to noise control, you can always add a widget do your home screen as well.
We appreciate your contribution to beta program.
Regards,
One UI Beta Team
userlQcCM1wRc8
Black Hole
Questions
While adding a widget is a work-aroundund to the situation described, it is not the solution. The expectation is that wearables, such as the watch, ring, and buds are in the wearable app.
Please move the buds back where they belong. Thanks!
Ibuwani
Questions
For me, I can listen to music but when i make a call neither I not the other person over the call can hear anything. It has become a mess. Any solution to it?
GalaxySpanner
Questions
So the 'experts' in the Samsung shop were unable to assist me, they agree it was strange that they would connect via bluetooth and play music but nothing else. Advised me to send them off for diagnostics/repair....
After talking with a proper expert online, many troubleshooting steps, he advised repair... It was only going through the process of arranging a repair/pickup that when coming to input the S/N it was not a UK/EU model, the engineer online looked up said S/N and identified it as a Chinese model. Now whilst i do not yet know if this is the root cause of the problem, i am going to return these, buy a legitimate UK pair and try again.... Update to follow in the coming weeks....
GalaxySpanner
Questions
Other things to note, they do not charge wirelessly, never had anything other than a red or flashing red light when charging via cable, the sync button on the bottom of the case never worked, intermittentent flashing on the stems, not visable from some devices when searching for them.... Mutliple issues, i can't say i can put them all down to being Chinese model variant but ya never know..... I have specific UK/EU models from Samsung, so when i have one of these i will see what the sketch is.
