Showing results forĀ
Search instead forĀ
Did you mean:Ā
Does anyone know how to get battery protection to work permanently
(Topic created: Tuesday)
S24Uuser
Cosmic Ray
Questions
I've always had this issue where my basic battery protection works for about 2 to 3 days before not working anymore. I then have to go into the boot menu. And clear cache partition just for it to cycle the 2 to 3 days again. Very annoying to do.
Are there any solutions?
1 Reply
youu
Red Giant
Questions
I would suggest reporting this issue to Samsung so they can see why battery protection isn't working correctly because mine is
