LED cover service killing battery
(Topic created: 10-02-2022 04:35 PM)
Ryan891
Supernova
Questions
I don't even own the LED cover. Screenshot below
Ryan891
Supernova
Questions
ChaosSaber
Honored Contributor
Questions
Some do, but I think it should be a separate install for those who do use it, theres a lot on my phone that I don't use at all but can't remove them, Netflix is one
Ryan891
Supernova
Questions
But why is it using so much battery? I literally don't even own the LED case
ChaosSaber
Honored Contributor
Questions
No clue
USBetaModerator2
Beta Moderator
Questions
Hello ,
Thank you for your feedback.
If you haven’t already, Please update Samsung Members app to latest version from the Galaxy store and send us an error report immediately after experiencing the issue from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
