Maximum Power Saving mode
(Topic created on: 10/27/20 2:18 PM)
Azariel
Questions
Can anyone find maximum power saving or minimal battery use?
Questions
yea it's in the top drop panel, it's way faster tooclipboard_image_1603851526433_1603851526433.jpg
Jakebs
Galaxy
Questions
It doesn't look like it's on the beta. Try putting it in the suggestions forum
Questions
ChetanGr
Questions
So for maximum power saving mode you should toggle on Limit apps and Home Screen in the power saving Screenshot_20201027-214748_Device care.jpg
tsnokian900
Questions
Just add the toggle switch Power saving mode from the quick panel. If you want high processing toggle enhanced processing and your good to go. Anything in-between you have to go into settings to manually make medium mode. Since power saving mode is no loner restricted to a few apps if you change the launcher you can easily run power saving mode and a custom launcher and get 2 or 3 days battery life easily. As long as you don't mind the processor being throttle down dramatically.
USBetaModerator
Beta Moderator
Questions
Hello,
Thank you for your post. We appreciate your contribution to the beta program.
Regards
One UI Beta Team
