No ring tones or sound notifications
(Topic created: 09-26-2022 08:26 PM)
tapdiggity
Galaxy
Questions
Ever since I enlisted to the beta program. I have not had any ringtones nor any audible notifications for my text messages. My sound is turned on but I get nothing as far sound. Is there another setting I need to turn on or enable? Please advice.
Cannonb87
Halo
Questions
Factory reset on original stable os then reinstall the beta.
TipsyTrex
Black Hole
Questions
Make sure notification volume is turned up. You can see an expanded volume panel by pressing the three dots on the volume panel that appears whenever you adjust volume via hardware buttons
