Showing results forĀ
Search instead forĀ
Did you mean:Ā
No vibration for edge panel
(Topic created: 11-17-2021 02:37 PM)
Phantom
Nebula
Questions
Did you guys remove the vibration upon touching the edge panel? It was very satisfying and handy.
1 Reply
USBetaModerator
Beta Moderator
Questions
Hello @Phantom ,
Thank you for your feedback. If you havenā€™t already, Please update Samsung members app to latest version from galaxy store and send us an error report immediately after experiencing the issue from the Samsung memberā€™s app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
