One UI 5.1 Questions for Battery Widget, Universal Gestures on Galaxy Watch 4 for non Samsung Devices
(Topic created: 06-21-2023 03:59 PM)
userx5NOP7RNaa
Questions
Hello,
I have installed the One UI 5.1 Beta and apps onto my Galaxy Watch 4.  I have 2 questions.
When I open the battery widget I see my Samsung Galaxy Note 10+ and my Galaxy Watch 4 but it does not show my Anker Liberty Pro 3 BT earbuds.  Is there a way to add them or is this only for Samsung products?
I cannot find where to turn on the Universal Gestures for going back and forward with apps by touching my finger to my hand in the Wear App on my Note 10+.  Can someone point me to it?  I found one gesture for closing my fist and moving it downward twice for recent app but none of the ones in the Beta 5.1 that are shown in the tips.
Also, how can I restart the tips that came up after the update if want to go through them again .
Thank you!
Greg
DaleNet
Nebula
Questions
Only shows Samsung products.
userx5NOP7RNaa
Questions
Thank you, you were fast with your answer!!
That is what I was guessing for the battery.
Would you have any info on the Universal Gestures or how to restart the Tips tutorial?
Greg
Dlpsr
Nebula
Questions
I have nothing on gestures and am not disagreeing with the other battery answer either.
My S23 Ultra does show other devices like my Phonak hearing aids in the widget
The difference may be the phones, I don't know for sure.
DaleNet
Nebula
Questions
The phone will show battery for other devices, he was asking about the Wearable app.  It will only show Samsung devices.
Dlpsr
Nebula
Questions
Ok, my mistake, sorry about that.
DaleNet
Nebula
Questions
You can go to your watch and select settings.  At the bottom you will find TIPS and TUTORIALS.
DaleNet
Nebula
Questions
No problem.  I am actually assuming he is talking about the Wearable app since most wireless ear pods come with their own app so you can see battery level and do settings.  That is what I have to do to check my Bose wireless devices.
userx5NOP7RNaa
Questions
Sorry for the confusion.
- Battery widget question;  I was asking about the widget on the watch to show my Anker Liberty Pro 3 earbuds power status since it has the ability to show 4 devices
- Universal Gestures, I have looked on the watch settings in the Wearables app running on my phone to try to turn this on but can not find it.  Only the limited one I mentioned
Thank you all for your answers!
DaleNet
Nebula
Questions
The tiles require a Samsung device that will also be in the Wearable app.
