AzureVice
- Mute
09-16-2021 05:50 AM in
Questions
Has anyone else noticed their battery dying faster than before they started the beta?
I'd usually be around 88% at this time in the morning
8:49am and I am now down to 80%
#batterydrain
- « Previous
- 1
- 2
- Next »
userr4ijxZyCts
Cosmic Ray
- Mute
09-16-2021 12:28 PM in
Questions
Same here was 100 at 12 now its 2:30 now its at 15 and I hardly use it
USBetaModerator
Beta Moderator
- Mute
09-16-2021 02:47 PM in
QuestionsHello @AzureVice
We would recommend clearing cache of the device
- Turn off the device.
- Press and hold the Volume Up key and the Side key.
- When the Android logo displays, release both keys.
- An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
- Press the Volume down key several times to highlight Wipe cache partition.
- Press Side key to select.
- Press the Volume down key to highlight Yes, then press the Side key to select.
- When the process is complete, Reboot system now is highlighted.
- Press the Side key to restart the device.
If issue continues to happen even a day or two after clearing cache, Please send us an error report from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
AzureVice
- Mute
09-17-2021 04:24 AM in
Questions
Good morning,
I wiped the cache so hopefully that will help. The drain was a bit ridiculous. Phone doesn't make it through the day anymore like on android 11
- « Previous
- 1
- 2
- Next »
