S23 Ultra UI 8.5 battery drain
(Topic created: 2 weeks ago)
MorningDew
Questions
Anyone else have the UI 8.5 Beta for the S23 Ultra and noticing the battery drain is twice as fast, compared to UI8? I usually charge phone once a day, for normal use. Now I'm charging it 2 times a day with normal use. Are there new settings I'm missing to see?
USBetaModerator3
Beta Moderator
Questions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
Gangabajgai
Questions
I am also experiencing the same thing. Hopefully they fix it on the next beta and release it really quick
