Sound control in quick panel and numbers in sound panel
(Topic created: 09-28-2022 09:58 AM)
userHBV6TadTaB
Suggestions
1. Is it possible to implement sound control in the quick panel.
The idea is that sound control is displayed when sound is played from a player: YouTube, Social media and browser and also from other apps.
It sometimes helps to adjust manually the sound control higher or lower or to the exact volume the user wish to have. It would be nice to have a choice about sound adjustment in the quick panel, the user has a choice whether sound control should always be displayed or not in the quick panel. Exactly the same as light adjustment always show in quick panel or not.
2. Is it possible to add numbers in the sound adjustment panel (where it shows ringtone, media, notifications and system)
TipsyTrex
Supernova
Suggestions
Sound assistant from Goodlock already allows per app volume control, and adds the individual apps in the pop up volume control panel
userHBV6TadTaB
Suggestions
Thanks,
But Good Lock is not available in all countries.
I wish sound control could be part of the quick menu in some way other than clicking sound buttons.
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
