Wifi Connection
(Topic created on: 10/9/20 12:20 PM)
TheMirageOMG
Questions
Has anyone had any issues with wifi connection after the beta update?
USBetaModerator
Beta Moderator
Questions
May i ask what issue are you facing with wifi connectivity ?
Claykin
Questions
I'm having link speed and throughput issues. On 802.11ac 5Ghz I'll get a 450Mb/s link then an hour later it drops to 54Mb/s. Even with strong signal. Actual download speeds drops from 350Mb/s to 20Mb/s. Only this device affected.
