Highlighted
Cosmic Ray
battery drain
On beta 3.0, a systems app, "configuration update", is draining to battery excessively, 92%. Is this normal for this beta? This has been happening for several days. I know that I can turn this off in settings, but I hesitate to do this if it is part of the beta. Yes, I cleared the cache twice with no change.
Please advise.
5 REPLIES 5
Highlighted
Cosmic Ray
Re: battery drain
Forgot to mention, I am using the S20 Ultra, unlocked.
Highlighted
Re: battery drain
This is not normal, please send a bug report to samsung. I would suggest turning it off and seeing if anything changes and/or till you have a definite answer.
Highlighted
Cosmic Ray
Re: Re: battery drain
will do. Thanks
Highlighted
Re: battery drain
The same thing happened to me now it has normalized.
Highlighted
Beta Moderator
Re: battery drain
Hello,
Thank you for your feedback. If you haven’t already, please send us an error report to help us debug the issue. Please also keep an eye out for any other issues you may encounter. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards
One UI Beta Team
