Rubber Feet for Samsung Grate
(Topic created: 02-20-2021 07:23 AM)
usertpzYlszfRl
Kitchen and Family Hub
I have searched hi and low for a place to order a grate for my gas range. I have a rubber foot issue and have read, at numerous sites, that Samsung suck when it comes to the rubber feet. You ultimately must purchase a new grate instead of $5 rubber feet. I do not a service call, I’m perfectly capable of removing and replacing a new grate. Can anyone tell me where I can order one, even if it’s an aftermarket grate. Samsung makes awesome TVs but that’s about it.
SamsungAl
We are glad that you brought this to our attention. Our job is to ensure that you are satisfied with your investment. Please contact our parts department J&J international by phone at 1-800-627-4368 or online at www.samsungparts.com whether your rubber feet have gone missing or melted off, they will be able to assist with ordering a replacement part(s). You can also send us a private message for further assistance, if applicable, with the following information below so that we can look into this further for you.
Send a message on Facebook
Send Message on Twitter
Sent Message to Moderator
  • Full Model Code:
  • Full Serial Number:
  • Photos of your symptoms:
We do research symptoms on a case by case basis.
Please note,  this forum is for the support of US products and customers. If your product is a non-US model please reach out to the country in which your product was manufactured/purchased for assistance: http://www.samsung.com/visitcountry
userKdnRiDYtIT
I am going through the same issue right now 2/21/21 with Samsung. I just need the little rubber feet replaced as they have melted or fallen off. I have reached out to them through their text messaging service and they have informed me I need call the parts department  so I can purchase new grates which cost over $108. The rubber feet for all other manufactures cost $5-$10. Can we say we are being robbed? I have all Samsung items. Maybe it’s time to switch to Whirlpool, Kitchen Aid, LG anyone other than Samsung!!! This is not acceptable!!!
user8QX03fh2ms
I have the same issue with model NX58M6650WS, new in 2019.  Samsung replaced the grates the first time the feet came off, only a couple months after we bought the range.  Now that it's out of warranty, they want about $340 for more grates since they still don't have the feet separately.  That's ridiculous, and if I had known about that I would have never bought that range.  I also bought an "extended warranty" that claimed to extend the manufacturer's warranty for 5 years of coverage.  They say that since the range still gets hot, a mere wobbly grate is not a problem.  I should have bought another LG range like we had before moving!
user8N2FGVXTQl
I'm having the same issue too. I would love to have a solution for this..
mc NX58H5600SS / AA
sn <HIDDEN>
 please lmk! Thanks.
SamsungAl
  • Full Model Code:
userclXE5xWvpm
Looking at some of these posts, Samsung seems to have a problem with the rubber feet on their gas range grates. I have the same problem with my grates. I sent Samsung a letter stating that there was nothing wrong with their grates. The problem is they DO NOT SELL THE FEET. Further, I told them my range was out of warranty. They replied that they would make a “one time accommodation” and replace my grates.
They said they ordered grates, and they would arrive in 5-10 days.
Last night I get a voicemail from Samsung telling me they are NOT going to replace my grates. The voicemail referred me to their distributor to purchase the grates.
Samsung, you need to clean up your act. Nobody I have communicated with has addressed my complaint.
userJKxr6WZZMU
The rubber feet should be an expendable part that is easy to replace or purchase.   It is wasteful and foolish to expect customers to replace the entire part the cheap rubber feet are supposed to protect.   This is happening to many of your customers, myself included, and it will cause me to consider another brand with better customer support/concern.
deb9025
I'm having same issue with the rubber feet on the grate for model#NX58M6850SS/AA. Anyone find a solution yet
usercl5uLjJtXv
Good afternoon. I’ve searched all over for replacement rubber feet for the grates on my gas range. The only solution cannot  be to purchase a new set of grates for $370 as opposed to replacing the rubber feet for $5-10? Please help.
SuperOvni
Supernova
Check Ebay
